EUROTRANS recently announced the reelection of Haffar Salim as president of their organization during the International Drive Conference that took place online November 17, 2022.
Force Control dynamometers featuring Positorq oil shear load brakes absorb extreme torque at very low speed, down to zero rpm. This allows them to accurately capture data at these critical junctures, when dynos equipped with traditional load brakes cannot.
Applied Motion Products New PH Series Mini Planetary Gearmotors are used with small step motors in NEMA 8, 11, and 14 frame sizes. The small design of the gearheads allows them to be paired with small motors and doesn't adversely affect the outside dimensions of the combined gearmotor.
