Let’s be clear about something
up front here: Delta Gear does not make parts for lawnmowers. This is a fairly flippant point that falls under the timeless, clichéd designation of “goes without saying.” Yet, not all that long ago,Tony Werschky had to say it.
The use of motor current signature analysis (MCSA) for motor fault detection — such as
a broken rotor bar — is now well established. However, detection of mechanical faults
related to the driven system remains a more challenging task. Recently there has been a growing interest for detection of gear faults by MCSA. Advantages and drawbacks of these
MCSA-type techniques are presented and discussed on a few industrial cases.
This paper presents an evaluation of measurements being taken on a 750 kW wind turbine gearbox being tested by the National Renewable Energy Laboratory (NREL). High-speed stage gears and bearings have been identified as critical components of the gearbox; during gearbox testing, these components were instrumented and tests were developed to evaluate loads on high-speed tapered roller
bearings (TRBs). In this paper an advanced finite element-based contact modeling procedure has been applied to model the high-speed
stage with the bearings fully modeled in order to evaluate strain levels. A major conclusion is that the strains of the slotted grooves are at such a level that they have acceptable signal-to-noise levels. This was verified by the results of the initial experiments presented here.
