The Spinea TwinSpin high precision reduction gear from DieQua is designed specifically for applications requiring zero backlash, high accuracy, high torsional rigidity and high tilting load capacity, in a compact design. They are ideal for robotics, rotary tables, machine tools and other precision machinery.
Bellows couplings first began to be
widely used by machine tool builders
in the mid-to-late 20th century. With the
advent of CNC technology, machine
engineers started looking to improve
upon some of the negative influences
traditional power transmission couplings
can have on a precision rotary /
linear motion system.
This issue we present our Hannover Fair preview.
As most of you know, Hannover is one of the biggest
trade shows on Earth, and by far the largest that includes a
significant focus on mechanical power transmission components.
