For several months, many economists have
been using the “R” word when it comes to
manufacturing. They say we’ve been in a global manufacturing recession since some time in the fourth quarter of
last year.
As with just about everything else
in the manufacturing world — and
all which that universe entails — it
depends. After all, that’s why the art
of manufacturing is a process — not
a one-system-fits-all discipline. Yes,
once that process has been properly
designed and correctly implemented
for a given manufacturing production
need, it may well run like the astest,
smoothest cookie-cutter-type operation
ever devised.
