One of the key challenges in the mining
industry today is maintaining throughput
in the face of ore grade quality that
has declined by 40 percent in the last
decade.
The changing landscape of hydraulic drives is leading many fluid power specialists to quickly adapt to using variable speed pump drives. Optimum utilization of these drives requires, in many cases, additional system design considerations.
EDITORS’ NOTE: “The Applications of Bevel Gears” is the excerpted third chapter of Dr. Hermann Stadtfeld’s latest book — Gleason Bevel Gear Technology (The Gleason Works,
Rochester, New York, USA; All rights reserved. 2014; ISBN 978-0-615-96492-8.), which appears here unabridged through the kind graces of Dr. Stadtfeld and Gleason Corp. Future installments will appear exclusively in Power Transmission Engineering
and Gear Technology magazine over the next 12 to
18 months.
