Implementing a power-on-demand concept based on variable speed drives allows for energy saving in any application
that involves pumps or hydraulic systems. And when used in combination with an intelligent wiring and communication system, relevant machine data can also be easily recorded
- the basis for comprehensive power management.
life in this application.
Synchronous drives are especially well-suited for low-speed, high-torque applications. Their positive driving nature prevents potential slippage associated with V-belt drives, and even allows significantly greater torque carrying capability. Small pitch synchronous drives operating at speeds of 50 ft/min (0.25 m/s) or less are considered to be low-speed. Care should be taken in the drive selection process as stall and peak torques can sometimes be very high. While intermittent peak torques can often be carried by synchronous drives without special considerations, high cyclic peak torque loading should be carefully reviewed.
