Heidenhain Corporation announces its participation in the upcoming NAEC (National Association of Elevator Contractors) 2023 Convention & Exposition. Connecting professionals from all over the elevator industry, NAEC will take place from September 10-13 at the Reno-Sparks Convention Center, Nevada.
The Timken Company is providing slewing drives for the second-largest photovoltaic (PV) solar tracking system project in Australia. Solar tracker manufacturer ATEC chose Timken's Cone Drive solution to help it overcome challenging wind conditions in the mountainous region of New South Wales, where the 280 MW Wollar Solar Farm is being constructed.
Omni Powertrain Technologies announces the development of a new electric powertrain designed for the propulsion of skid steers. The new product features a robust Omni gearbox paired with a Magelec Propulsion axial flux motor.
Atlas Energy Solutions has selected Voith Turbo to supply a total of 21 TurboBelt 800 TPXL fill control fluid coupling drives (including spares) to power 42 miles of conveyor belt as part of Atlas Energy Solutions’ historic Dune Express project. ELIN Motoren, a Voith company, will also provide 21 customized low noise electric motors for the project, including spares. Once in operation, the overland conveyor system will serve as a low-impact transport system, taking sand from Texas to New Mexico while establishing a new world record for a single conveyor flight without a mid-belt drive at an impressive 16.3 miles overall single flight length.
Electric drives often need to operate under high voltages up to 800 V to provide more power and higher speeds. However, the risk of partial discharges increases at these voltages. In combination with high operating temperatures, these can locally damage the insulation and lead to machine failure. However, a good impregnation ensures not only electric insulation but also copper bonding, to mechanically strengthen the electric motor, and air gap filling, to allow a better heat transfer.
Allied Motion Technologies Inc., a global designer and manufacturer of precision and specialty motion, controls and power products and solutions for targeted industries and applications, announced that shareholders approved its corporate name change to Allient Inc. at a special meeting of shareholders held on August 11, 2023. The new name will be effective August 23, 2023, and at the opening of the markets that day, the company’s shares will commence trading under the new ticker ALNT on the Nasdaq.
Neugart GmbH celebrated the official groundbreaking ceremony for its new Plant 3 at its Kippenheim headquarters on July 26. With an investment of more than 25 million euros and a floor space of over 7,000 square meters, the company is thus setting a forward-looking example for further growth and even improved production processes.
The Transfluid MPD (multiple pump drive) is an innovative split drive module designed to sandwich between the main diesel engine and transmission. It features an integrated flexible coupling on the input side and an SAE standard flywheel and housing on the output side. Gear driven PTO heads provide multiple pump pads for mounting pumps, while the output flywheel ensures adequate power transfer to drive larger transmissions.
