Portescap introduces the 08ECP20 brushless DC slotless motor, a mini actuation solution ideal for engineers looking to downsize devices and applications without compromising on performance or reliability. The 08ECP20 is the smallest frame size to join Portescap’s Ultra EC portfolio.
Moticont has released the GVCM-022-013-01 Linear Voice Coil Servomotor. This compact .875 in. (22.2 mm) diameter high speed, high force-to-size linear motor features high accuracy and high repeatability when operated in a closed loop as a DC servo motor. This brushless servo motor is clean, quiet and has long life, low mass and high acceleration/deceleration for high throughput.
AMETEK Dynamic Fluid Solutions (AMETEK DFS) and the former Bison Gear and Engineering Corp. have combined to create a more robust, customer-centric business named Bison. The newly created Bison, a business of AMETEK, Inc., will provide a broader range of high-quality products, unparalleled customization and integration support, accelerated time to production, and global manufacturing flexibility.
With its drive technology webinars, which are around one hour in length, Faulhaber provides the possibility of bringing your knowledge up to speed without having to spend too much time and effort. Missed webinars can now be accessed online at any time. This requires one-off registration, which is then valid for an entire year.
Portescap announces the release of the 45ECF brushless DC flat slotted motor, the latest addition to join our flat motor portfolio. The 45ECF features a performance optimized design that utilizes an outer rotor configuration with an overall diameter of 43.2 mm and a body length of only 22.5 mm. The motor features hall sensors to easily control speed and torque and can be provided sensorless based on application requirements. Additionally, the motor can be used in combination with existing gearbox designs to provide high output torque at required operational speeds.
Orbex Group, a U.S.-based supplier of slip rings and electric motors, has introduced two new custom products to its offering of precision motion solutions. These custom flat brushless DC (BLDC) motors provide smooth motion, high precision and excellent power density, as well as an integral gear reducer in a compact package.
