DC motors possess linear relationships that allow for very predictable operation. For instance, if enough voltage is applied across the terminals of a DC motor, the output shaft will spin at a rate proportional to that applied voltage. You can take the ratio of the applied voltage over the rated voltage and multiply that number by the no load speed and get the running speed.
Without the sun, there would be no
Earth and no life. However, our knowledge about our home star is still very limited. This is about to change. In 2018, the European Space Agency (ESA) will send its Solar Orbiter into space, equipped with a thick heat
shield.
