Are you looking for one simple formula to help you choose between centralized and decentralized motor control? Unfortunately, such a formula does not exist. However, evaluating the overall size of the system, comparing labor and material costs, and maintaining flexibility can help guide engineers in the right direction.
The transverse flux permanent magnet motor -- also known as a hybrid step motor or hybrid servo motor -- has a wide range of performances, depending upon how you drive these motors, and whether you operate them in open loop or one of the many variants of closed loop methods you use. In this third installment we will cover some of the many ways to drive these motors, as well as how these choices affect the performance of these motors.
One of the fun parts of the motion industry is involvement in popular movies! Motor specifications can be a bit rough: "I need to spin a 120-pound actor (and chair) 180 degrees in one-half second. He will be sitting up-right."
