Couplings. There certainly is no shortage of couplings - or things to couple them with. There also seems to be no lack of applications for them. You say you need to reduce the transmission of shock loads from one shaft to another? That's a classic application for shaft couplings; but really, couplings are application-intensive. They're everywhere.
It is hard these days to find any device that is not IoT-compatible or WiFi-connected. I recently had a new well pump installed that requires an iPhone for setup, which makes it hard for me to check or change the setup since I do not own an iPhone. In Olden Times, you had potentiometers or RS-232 connections - and that was fine.
This is an article about motors - preventive motor maintenance, actually.
And something else - mechatronics. In
today's high-tech manufacturing and industrial use environments, it is near impossible to talk about equally complex motor maintenance and repair-or-replace protocols without it.
