The Ogura MCNB-HS Series power-off spring applied brakes have oversized bores to allow wires to pass through the shaft’s hollow bore. They accommodate encoders, cables, hoses, shafts, and tools. The ratio of the brake’s field core diameter to outer diameter is leading the industry.
Adjusting a stop and hold position in an automated system is made easy using Miki Pulley BXW brakes with the manual release lever feature. It allows the operator to depress the lever and make a manual adjustment when the system is powered off. The lever also allows easy system indexing in the event of a power failure.
Force Control dynamometers featuring Positorq oil shear load brakes absorb extreme torque at very low speed, down to zero rpm. This allows them to accurately capture data at these critical junctures, when dynos equipped with traditional load brakes cannot.
Force Control Industries’ offers a full lineup of motor brakes, clutches, and clutch-brakes in washdown configurations for food, chemical, and pharmaceutical processing applications. MagnaShear and Posistop motor brakes and Posidyne clutches and clutch-brakes are totally enclosed with heavy duty, cast housing which offers additional protection against moisture, water, saltwater, caustic spray, and chemicals.
AD Bearings & Power Transmission welcomed over 140 member and supplier partner attendees to its annual Network Meeting from August 23-25 in Frisco, Texas. The meeting brought the division’s members and suppliers together to discuss industry trends, celebrate a year of growth and collaboration, and learn about important divisional updates.
Attendees and exhibitors from across the globe are getting ready to make their way to CONEXPO-CON/AGG and the International Fluid Power Exposition (IFPE) next March, after government and corporate travel restrictions have either been reduced or eliminated since the 2020 show.
David Brown Santasalo Australia recently completed a full strip and rebuild of a Zollern ZHP 4.33 Rope Winch Drum for valued mining industry partner, Zollern. The 7,550 kg Winch Drum powers a coal loader, with an output torque of 400 kNm (Stat Max) and an input torque of 893 Nm.
Force Control Industries presents a maintenance-free, no-adjustment crane brake that virtually eliminates crane downtime as well as the need to perform maintenance and adjustment at height. The MagnaShear motor brake employs oil shear technology, providing longer service life in demanding applications like the frequent start/stop cycles seen on cranes, hoists, and winches.
