SKF has entered into a collaboration that will combine Quaker Houghton’s industrial oils and application expertise with SKF RecondOil’s Double Separation Technology (DST) to enable the industry to more efficiently utilize its resources by reducing the unsustainable linear of use of oil. The circular use of oil will also help reduce the industry’s environmental footprint through a reduction in CO2 emissions, lessen the amount of neat cutting oil purchased, and reduce handling and disposal costs whilst providing significant performance improvements.
Axially space-saving, economical, IP65-compliant and designed for high radial and axial forces at the output: The Neugart WPLHE combines all the advantages of the successful PLHE, as a right-angle variant.
The Power Transmission Distributors Association (PTDA) will convene for the PTDA 2022 Industry Summit in Nashville, Tenn. on October 27-29, 2022. With more than 500 delegates in the power transmission/motion control (PT/MC) industry expected to attend, representing over 200 PTDA distributor and manufacturer companies, the Industry Summit—themed “Amp Up”—will offer cross-channel networking, shared learning and collaborative experiences.
ONYX Insight examines how digital tools can provide wind energy solutions, from day-to-day problem solving to future-proofing operations and maintenance (O&M) strategies through condition monitoring technologies.
June 22 was Climate Action Day at all Schaeffler locations worldwide, from Herzogenaurach, Germany to Taicang, China, and from Port Elizabeth, South Africa to Fort Mill, USA.
