The Timken Company has acquired Lagersmit, a Netherlands-based manufacturer of highly engineered sealing solutions for demanding marine, dredging, water, tidal energy and other industrial applications.
NSK has developed HTF-SRM Ball Screws, a high-speed, heat-resistant version of its high-load drive ball screws, ideal for high-cycle, thin-wall molding in electric injection molding machines.
Randy Stott, publisher of Power Transmission Engineering and Gear Technology magazines, recently sat down with Norm Parker, technical fellow and technical manager for Torque Transfer Systems at Stellantis, to discuss bearing technology during the Motion + Power Technology Expo in Detroit.
NTN Bearing Corporation of America is proud to share its story of support for a local animal rescue. On Thursday, November 16th, NTN donated a Mercedes-Benz Sprinter van with its cargo hold full of supplies to Wright-Way Rescue, but it didn’t happen without a bit of good fortune.
NTN, the parent company of BCA Bearings and Bower Bearings, is proud to announce the receipt of a 2023 Automotive Communications Award from Women in Auto Care. NTN received the award in the “Business-to-Business – Promotional Goods, Gear, Marketing Collateral” category for its BCA and Bower “Summer Cruisin”
Promotions.
AutomationDirect recently added the EQP Global SD severe duty motors from Toshiba. The Toshiba EQP SD series motors are designed to withstand the most severe conditions. Since most AC motor failures are a result of failed bearings, these inverter-duty motors feature oversized 300-series bearings for maximum motor longevity.
Bega Special Tools introduces a portable multi-purpose induction heater on the North American market. The MF Quick-Heater 3.0-3.5 kW can be used for mounting, dismounting and pre-heating purposes. Weighing less than 8 kg and fitting in a small carrying case, this easy-to-use but powerful tool is just plugged into the mains 230 V. It can be used in difficult circumstances where other systems are impossible to operate, for instance where there is little space to work in or where no open fire is permitted. The heater’s flexible inductors are ideal for a large variety of parts with a maximum diameter of 120 mm. Application examples can be found in all types of industries.
Schaeffler recently displayed its automotive aftermarket solutions at the AAPEX show, hosted at the Venetian Expo in Las Vegas. Under the theme, “Your business is our focus,” Schaeffler hosted customers and industry partners at its booth, showcasing products and service solutions that enhance the vehicle’s life cycle, as well as technologies that support the transition to electric mobility.
A leading global copper producer has achieved exceptional results through the implementation of Vesconite Hilube wear-resistant bushings on load haul dump machines (LHDs). Departing from traditional bronze bushings, the mining company's adoption of Vesconite Hilube on Sandvik and Caterpillar LHD booms has led to an unprecedented increase in bushing lifespan, exceeding their initial expectations.
