The European Southern Observatory’s Extremely Large Telescope (ESO’s ELT), now being built in Chile, will be the world’s largest visible/near-infrared telescope on completion in 2028. Its 39m-wide main mirror comprises 798 separate hexagonal pieces, attached to a base structure using steel flanges and SKF Vibracon adjustable chocks.
A Vesconite and Vesconite Hilube wheel and bushing combination has been deployed at a prominent hydroelectric company in New Zealand, expanding a growing set of hydroelectric reference cases for these bearing materials.
Carrying out routine maintenance can be a chore, but failing to complete regular checks on important pieces of machinery can result in unexpected downtime and lost productivity. Sulzer’s service center in Colton, CA, recently completed an urgent repair on a 700 HP (522 kW) motor, caused by a failed bearing, that could have been easily avoided.
SKF is presenting its technologically innovative solutions tailored for customers in focused industrial segments at the virtual SKF Tech & Innovation Summit. The solutions are developed to address the needs of greater reliability, energy efficiency, and high-performance as well as to support customers on their sustainability journey.
NTN, the parent company of BCA Bearings, is pleased to announce the receipt of a 2024 Content Excellence Award from the Automotive Content Professionals Network (ACPN). BCA Bearings received the Gold Award for ACES and PIES Data in the Large Category (250,000+ applications) at the 2024 Auto Care Connect/ACPN Annual Conference, held recently in Chicago, Illinois.
The PRT-02-30-WPC slewing ring bearing is another step forward by Igus toward integrating renewable raw materials into industrial production. Made of 50 percent wood and 50 percent high-performance plastics, the cost effective and lubrication-free slewing ring bearing balances strength and durability with a proven low CO2 footprint of just 0.0577 kilograms. By comparison, the PRT-02-30-ECO — already made from 97 percent regranulate — has a CO2 equivalent of 0.819868 kg.
At a Gulf Coast seawater cooling pump station, the resilience of Vesconite Hilube bearings in hypochlorite came to the forefront, showcasing their superiority in challenging environments.
The ATR-V-60-60 Series (-01 thru -04) of Dual-axis Elevator-Rotary Stages has been released by Optimal Engineering Systems, Inc. (OES). These compact, Elevator-Rotary Stages feature a high stability Elevator Stage with 120 mm x 80 mm table and 60 mm +/- 2 mm of vertical travel and a load capacity of 5.0 kg. A 60 mm diameter Rotary Stages is mounted vertically. The scissor lift design of the elevator stages combined with precision roller bearings and slide rails assures smooth motion and very high parallelism throughout the travel of the table. The rotary stages capable of continuous rotation feature high precision bearings and 90:1 worm gear.
Caterpillar Inc. announces the awarding of Supplier Excellence Recognition Process (SER) Certification to the NTN Hamilton plant. This prestigious acknowledgment underscores NTN's consistent demonstration of excellence in product quality, service delivery, and overall performance in its partnership with Caterpillar.
