life in this application.
Mechanical guiding systems, such as crossedroller bearings, work well for most motion control applications; however, when precision, angular repeatability, and geometric performance
(runout, straightness) are critical or
where submicron bearing rumble is problematic, air bearings are recommended. An air-bearing stage is a rotary or linear positioner that floats on a cushion of air, using one of several preload mechanisms, nearly
eliminating mechanical contact and thus wear, friction, and hysteresis effects. Here are eight reasons why an air-bearing stage might be the right choice for your application:
The average travel time to
work in the United States is
25.4 minutes, according to
the U.S. Census Bureau. This
number is probably low if you factor in
a traffic accident in New York City, light
rain in Chicago or it's simply Tuesday
in Los Angeles. It's safe to say 25.4
turns into 45 minutes in many areas
of the country at seven o'clock in the
morning.
Eddy Swiben, branch manager at BDI
Canada, explains how to problem solve
on an automatic cutter for tissue rolls.
“This is a very major paper tissue manufacturer that sells paper tissue rolls all over America.” They roll paper tissue just like newsprint paper mills do. When the product is finally done and dried, they need to roll it on a light carton core 20-ft. long.
Bearings are an essential component
in the majority of mechanical
designs and equipment.
It is important to consider the
most effective materials when designing
industrial machinery, especially in
applications where water or other liquids
are present. Many materials will
be unable to overcome the challenges
associated with operating in a wet or
corrosive environment.
