Power Transmission Engineering (PTE) Has Your Bearing Education, Training, and New Developments Covered Every Issue
February 14, 2017
PTE covers bearings in every issue, from application stories to technical articles and the latest technology from the major suppliers. Here is a selection of some of our most recent and most popular articles on bearings:
A four-point contact ball bearing makes it easy to simplify
machine designs that combine radial, thrust and moment
loads, because it can handle all three simultaneously. They
are primarily used for slow-to-moderate-speed applications,
or where oscillatory movement is predominant.
The air-oil, two-phase flow inside the multiple-point, oil-jet lubrication ball bearing was studied based on CFD (computational fluid dynamics) theory and technique, and compared with single-point, oil-jet lubrication. The results indicate that the air-oil distribution inside the bearing with multiple-point, oil-jet lubrication is more uniform than single-point injection.
