Digital transformation is an ongoing process so we can expect to see this year's breakthrough trends continuing to shape society into next year. But how will these trends impact robotics and automation and what can the manufacturing industry expect to see next year?
Siemens Digital Industries Software has announced that Space Machines Company (SMC), an Australian space on-orbit services and logistics startup, has used the Siemens Xcelerator portfolio of industry software to design and build the Optimus Orbital Servicing Vehicle. One of the largest commercial spacecrafts being designed, manufactured, and assembled in Australia, is in development at the University of Technology Sydney’s Tech Lab.
NSK has developed HTF-SRM Ball Screws, a high-speed, heat-resistant version of its high-load drive ball screws, ideal for high-cycle, thin-wall molding in electric injection molding machines.
Velo3D, Inc. has announced its Sapphire family of 3D printers are the first to achieve the U.S. Department of Defense’s (DoD) Green-level STIG (Security Technical Implementation Guide) Compliance. The certification allows Sapphire printers to be connected to the DoD’s Secret Internet Protocol Router Network (SIPRNet) and gives customers the confidence their metal 3D printers are hardened against potential cyberattacks.
VCI bags allow auto parts manufacturers and suppliers to eliminate greasy rust preventatives and opt for the dry protection of VCI film instead. Unfortunately, some VCI bags are doomed to failure, leading to the very corrosion that the VCI bag user was trying to prevent. To avoid these negative consequences, Cortec shares the best path to making sure your next VCI bag is the corrosion solution and not the problem.
Intellidrives Theta 2 theta stage consists of two rotation stages arranged in such a way that axis of rotation for both the stages are same. Both stages have preloaded ball bearing guides for wobble free rotation and positioning. 360° limitless movement is possible for inner and outer stages.
The Ohio State University was joined by Ohio Lt. Gov. Jon Husted, congressional leaders, Honda, Schaeffler Americas and JobsOhio officials recently to announce the creation of a new battery cell research and development center.
The cylindrical die rolling process can produce helical, axial, and annular forms on shaft-like parts at high rates of speed with precision tolerances.
Why use the rolling process to produce high accuracy lead screws, actuator screws, and other power transmission components rather than traditional cutting processes such as turning, grinding, milling, whirling, or hobbing? Rolling processes and cutting processes both produce a precise form on the workpiece. But if the form geometry, tolerances, and material selection allow, rolling is the process to beat. Speed, surface finish, fatigue strength, precision, dimensional stability, and material savings are some of the primary advantages realized when the rolling process is applied.
Designing linear motion systems for washdown applications requires careful component selection to solve problems associated with contamination as well as liquid and chemical interactions.
December 1, 2023
This article examines the sound engineering practices and design principles needed to ensure the performance of mechanical linear motion components in sanitary washdowns or chemically cleaned environments. Relevant regulations and agencies, washdown-compatible materials, and best mounting practices and motion components for washdown applications are also discussed.
