The cylindrical die rolling process can produce helical, axial, and annular forms on shaft-like parts at high rates of speed with precision tolerances.
Why use the rolling process to produce high accuracy lead screws, actuator screws, and other power transmission components rather than traditional cutting processes such as turning, grinding, milling, whirling, or hobbing? Rolling processes and cutting processes both produce a precise form on the workpiece. But if the form geometry, tolerances, and material selection allow, rolling is the process to beat. Speed, surface finish, fatigue strength, precision, dimensional stability, and material savings are some of the primary advantages realized when the rolling process is applied.
Designing linear motion systems for washdown applications requires careful component selection to solve problems associated with contamination as well as liquid and chemical interactions.
December 1, 2023
This article examines the sound engineering practices and design principles needed to ensure the performance of mechanical linear motion components in sanitary washdowns or chemically cleaned environments. Relevant regulations and agencies, washdown-compatible materials, and best mounting practices and motion components for washdown applications are also discussed.
The 2023 SPS trade fair in Nuremberg represented an important opportunity for Bonfiglioli to showcase its experience and expertise for industrial automation. This included mechatronic solutions specifically designed for packaging, intralogistics, robotics and IoT applications.
NTN Bearing Corporation of America is proud to share its story of support for a local animal rescue. On Thursday, November 16th, NTN donated a Mercedes-Benz Sprinter van with its cargo hold full of supplies to Wright-Way Rescue, but it didn’t happen without a bit of good fortune.
Routine refurbishment of important rotating machinery is vital for continued, reliable operation but if the original equipment manufacturer (OEM) fails to deliver an optimum service, what other options are available? For one oil company in Nigeria, issues with a gas compressor following an overhaul led to the maintenance team looking for an alternative solution. Sulzer was then selected to support the oil company, not only for its extensive experience in this equipment, but also its local service center that offered a tailored approach.
Stock Drive Products/Sterling Instrument (SDP/SI), a
Designatronics, Inc. company, completed and passed its recertification AS9100:D and ISO 9001:2015
quality system audit. The audit, conducted by Intertek over a 5-day period, certifies SDP/SI’s quality
management system conforms to AS and ISO standards.
A leading global copper producer has achieved exceptional results through the implementation of Vesconite Hilube wear-resistant bushings on load haul dump machines (LHDs). Departing from traditional bronze bushings, the mining company's adoption of Vesconite Hilube on Sandvik and Caterpillar LHD booms has led to an unprecedented increase in bushing lifespan, exceeding their initial expectations.
Solid Edge is a portfolio of affordable, easy-to-use software tools that address all aspects of the product development process. Solid Edge combines the speed and simplicity of direct modeling with the flexibility and control of parametric design – made possible with synchronous technology. The following Q&A discusses Solid Edge 2024 with Dan Staples, vice president, mainstream engineering, Siemens Digital Industries Software.
