As with just about everything else
in the manufacturing world — and
all which that universe entails — it
depends. After all, that’s why the art
of manufacturing is a process — not
a one-system-fits-all discipline. Yes,
once that process has been properly
designed and correctly implemented
for a given manufacturing production
need, it may well run like the astest,
smoothest cookie-cutter-type operation
ever devised.
The secondhand on the Doomsday
dial ominously spins around the face,
slowly but ever so surely inching the
motor industry towards its inevitable
terminus:
This issue we take a long, hard look at motor efficiency, and you should, too. After all, electric motors used in industrial settings are the single largest consumer of electricity in the United States. Upgrading your electric motors is not only good for the environment, but it’s
also good for your bottom line. Sure, saving electricity lessens
the burden on our country’s energy infrastructure. But it
also saves you money in the long run.
