finished products.
Power Transmission Engineering is collaborating with the Bearing Specialists Association (BSA) on a special section within the magazine. Bearing Briefs will present updated reports on bearing topics for each issue in 2016. Complimentary access to all BSA Bearing and Industry Briefs is available on the BSA website at www.bsahome.org/tools. Additionally, our new Field Notes section on page 34 will feature field reports from BSA’s Certified Bearing Specialists.
Third-quarter earnings are confirming the worst-case scenario, i.e. — not only are energy related end markets in a downturn, but conditions continue to worsen.
