Gears and gear racks used for transmitting torque and forces within gearboxes are typically made of hardened steel. For many other uses and applications, gears and racks made from plastic are the better choice. These generally require no lubrication and are lighter, quieter, less expensive, and more resistant to corrosion than metal gears. This is why JW Winco is expanding its range with polyamide gears and racks that can transmit high forces and torques.
Drop-in system offers tightest inner radius in the market for reduced footprint
February 8, 2023
Regal Rexnord Corporation introduces its new Rexnord Curve System with 1540 Series MatTop Chain for conveyor lines requiring a zero tangent 180 and/ or 90-degree curve. The system offers the tightest inner radius (420 mm) and smallest transfer (15 mm) in the industry, for greatly improved space utilization and package handling.
As shippers and logistics handlers continue to struggle with supply chain delays, Mitsubishi Gas Chemical America recently introduced the RP System to the North American market to protect critical components from moisture and oxygen damage that can occur during shipping and long-term storage. Manufactured in Japan, this unique packaging solution is designed to safeguard electronics, automotive parts, and industrial components from rust and oxidation.
CMES Robotics and BHS robotics recently announced that they will be demonstrating mixed case palletizing of various box sizes utilizing an ABB midrange 6-axis robot at Pack Expo International 2022. The event will take place October 23 -26 at McCormick Place in Chicago.
Cortec Corporation is proud to be named a BioPreferred Program Champion. Cortec recently received this badge of honor in recognition of its involvement and faith in the USDA BioPreferred Program, which celebrates its 20th anniversary this year.
Force Control Industries’ offers a full lineup of motor brakes, clutches, and clutch-brakes in washdown configurations for food, chemical, and pharmaceutical processing applications. MagnaShear and Posistop motor brakes and Posidyne clutches and clutch-brakes are totally enclosed with heavy duty, cast housing which offers additional protection against moisture, water, saltwater, caustic spray, and chemicals.
