A high force Linear DC servomotor from Moticont has been added to their expanding line of voice coil or moving coil motors. The LVCM-095-038-01 Linear Voice Coil Motor is a true servo motor featuring zero cogging, high accuracy, and high repeatability when operated in a closed positioning loop
In an age of online shopping and mass production, distribution centers are on the rise. Naturally, the amount of packaging is also increasing, and a practical solution is needed to close the loop on recycling so much waste. One major tool distribution company in the U.S. Midwest has found its own “circular economy” answer to this problem by using EcoShield Heat Sealable Paper to recycle used boxes into dunnage bags.
As a pioneer in adopting traditional industrial robots, the automotive manufacturing industry has significantly improved its productivity and efficiency. Although traditional industrial robots have presented significant benefits, one of the fundamental challenges is their high downtime costs. Industrial robots are dangerous and need to be physically separated from human operators. The physical separation means that if a robot malfunctions, human operators must shut all the machines at a production line before entering the robot's working space.
Gears and gear racks used for transmitting torque and forces within gearboxes are typically made of hardened steel. For many other uses and applications, gears and racks made from plastic are the better choice. These generally require no lubrication and are lighter, quieter, less expensive, and more resistant to corrosion than metal gears. This is why JW Winco is expanding its range with polyamide gears and racks that can transmit high forces and torques.
Drop-in system offers tightest inner radius in the market for reduced footprint
February 8, 2023
Regal Rexnord Corporation introduces its new Rexnord Curve System with 1540 Series MatTop Chain for conveyor lines requiring a zero tangent 180 and/ or 90-degree curve. The system offers the tightest inner radius (420 mm) and smallest transfer (15 mm) in the industry, for greatly improved space utilization and package handling.
As shippers and logistics handlers continue to struggle with supply chain delays, Mitsubishi Gas Chemical America recently introduced the RP System to the North American market to protect critical components from moisture and oxygen damage that can occur during shipping and long-term storage. Manufactured in Japan, this unique packaging solution is designed to safeguard electronics, automotive parts, and industrial components from rust and oxidation.
