PBC Linear has expanded its comprehensive portfolio to include Miniature Metric Ball Screw Assemblies. Building on their lead screw technology, this combination of precision-rolled screw and compact nut is driving exceptional performance from an economical package. Manufacturers of sophisticated laboratory equipment, medical devices, semiconductors, and other automation applications will find these high-precision ball screws a valued solution to their small-scale linear motion needs.
Axially space-saving, economical, IP65-compliant and designed for high radial and axial forces at the output: The Neugart WPLHE combines all the advantages of the successful PLHE, as a right-angle variant.
Sensors Expo & Conference got its start 37 years ago with a focus on sensor technology. Over the years it has expanded and diversified to include the electronics technologies and embedded systems that work hand-in-hand with sensors, as well as new and emerging application areas such as IoT, Connectivity, Autonomous, Medical, and more. Join us as we explore the entire ecosystem, from sensing to processing to analyzing and connecting.
A high force-to-size ratio is just one of the many features of Moticont’s GVCM-051-089-02 Linear Voice Coil Actuator with Built-in Bearing. The actuator applies up to 66.4 N (14.9 lbs.) of continuous force and 210 N (47.2 lbs.) of peak force.
Piezo Motion, a Brain Scientific company, and Micro Technology Group (MTG) recently announced a partnership. Piezo Motion is a developer and manufacturer of automation technology. MTG, headquartered in Mansfield, Massachusetts, is a business development company providing technical marketing and sales services for leading manufacturers.
