After a long and successful OEM partnership with Ansys, RBF Morph has two proprietary products featured among the world simulation leader's offerings: Ansys RBF Morph Fluids and Ansys RBF Morph Structures. The two simulation tools are based on RBF Morph's 10+ years of experience with 100+ global customers, including some of the top players and OEMs in the automotive and aerospace industries.
Ogura’s new MCNB-Z series Spring Applied Brakes are changing the way robotics and medical equipment designers look at power-off holding brakes. These are used for both safety and precision motion control. For decades, permanent magnet type brakes were the only reliable solution. This is no longer the case, thanks to this new breakthrough design.
The HVCM-051-032-013-01 Linear Voice Coil Motor released by Moticont, features a high force-to-size ratio and a 19.1 mm (0.75 in.) stroke. A low inertia, high acceleration/deceleration, high speed, clean and quiet, non-commutated, hollow core brushless servomotor, the HVCM-051-032-013-01 Linear Voice Coil Motor is ideal for applications such as: Testing, optical focusing, positioning, laser beam steering, laser drilling, cutting and machining, medical diagnostic equipment, scanning, wafer handling, dynamic vibration absorption, sorting, and assembly applications.
Kurt Hydraulics has introduced a new lineup of stainless-steel couplings for applications ranging from marine hydraulics to food production and medical processes to fertilizer and chemical handling or other tough applications requiring washdowns.
Harmonic Drive, a leading manufacturer of precision motion control technology, is pleased to announce the release of the FHA-C Mini Actuator with Integrated Servo Drive. The FHA-C Mini Actuator features a highly efficient, integrated servo drive that allows for precise control of position, velocity, and torque.
Optimal Engineering Systems, Inc. (OES) has added four goniometers to their expanding catalog of high precision positioning stages. The new, AK160-30 Goniometer Series feature precision ground worm gears with a 400:1 ratio and pre-loaded cross roller guides offer +/- 30 degrees of travel with 30 kg of load.
Portescap announces the release of the 45ECF brushless DC flat slotted motor, the latest addition to join our flat motor portfolio. The 45ECF features a performance optimized design that utilizes an outer rotor configuration with an overall diameter of 43.2 mm and a body length of only 22.5 mm. The motor features hall sensors to easily control speed and torque and can be provided sensorless based on application requirements. Additionally, the motor can be used in combination with existing gearbox designs to provide high output torque at required operational speeds.
It’s called the d2, a small, lightweight, nanoliter microplate dispenser—say that five times fast— used in lab automation to handle a variety of liquids. Created by UK Robotics, the liquid handler was launched in 2022 to shakeup the possibilities of moving liquids around the lab on a budget.
