The growing demand for drinks at convenient locations: work, school, gym, transport, leisure – is being driven by the global trend towards urbanization, fueled in turn by inexorable population growth. Inevitably, snowballing consumption increases the pressure on manufacturers, and also on the machines upon which they rely.
Binder USA offers M12 connectors with all external parts – threaded locking ring, housing, and pressing screw – constructed of stainless steel. The cable clamp is constructed of PTFE, the seal is made of Viton, and rounded surfaces facilitate cleaning.
Gears and gear racks used for transmitting torque and forces within gearboxes are typically made of hardened steel. For many other uses and applications, gears and racks made from plastic are the better choice. These generally require no lubrication and are lighter, quieter, less expensive, and more resistant to corrosion than metal gears. This is why JW Winco is expanding its range with polyamide gears and racks that can transmit high forces and torques.
The first fully automated McDonald's has arrived in Fort Worth, Texas. Here, a conveyor belt serves customers food they order online or using a kiosk machine. The fast-food restaurant has no seats, tables or drive-thru greeters.
Opto Diode Corporation, an ITW company, introduces the AXUV100G, a 100 mm x 100 mm active area electron detection device specially designed for use in radiation detection applications.
Food production is an essential, but often overlooked, component of our food chain. Reliable, efficient machinery plays a key role in the food processing industry—and ball bearings are essential to the performance of this equipment. Designers and engineers are faced with important decisions when specifying bearings used in food processing equipment, which must withstand challenging operating environments while meeting stringent safety requirements.
Force Control Industries’ offers a full lineup of motor brakes, clutches, and clutch-brakes in washdown configurations for food, chemical, and pharmaceutical processing applications. MagnaShear and Posistop motor brakes and Posidyne clutches and clutch-brakes are totally enclosed with heavy duty, cast housing which offers additional protection against moisture, water, saltwater, caustic spray, and chemicals.
