Regal Rexnord Corporation will feature complete conveying solutions for the craft brew industry including Rexnord and System Plast Run Dry, TableTop and MatTop conveyor chain and Sealmaster Stainless Steel Gold Bearings at the 2023 Craft Brewers Conference, Booth #2625. The show will take place at Music City Center in Nashville, Tennessee, from May 7–10, 2023.
SKF has extended its Microlog Analyzer family of data collection devices with a new model that offers faster measurement collection and greater diagnostic power.
FDA/USDA certified, two, three and four post, stand-off bearing flange blocks are setting a new standard for performance and hygienics. These new stand-off bearing flange blocks now available from LM76 reduce the surface area where mold and bacteria can thrive, even from the most through sanitizing operations. Long life hybrid stainless steel Si3N4 Silicon Nitride ceramic ball bearings in stainless steel bearing blocks are coated with a smooth non-water absorbing polyamide coating certified by EHEDG, USDA, and 3-A. These FDA/washdown flange bearings employ hybrid stainless steel/ceramic ball bearings that are sealed from contaminates and bacteria via a patented shaft seal system. The seals resist water, cleaning solutions - keeping lubrication from being corrupted and evacuated.
This year, the Hermes Startup Award goes to the Netherlands. The young company MantiSpectra from Eindhoven was awarded the coveted Startup Award for its ChipSense product by the jury.
The growing demand for drinks at convenient locations: work, school, gym, transport, leisure – is being driven by the global trend towards urbanization, fueled in turn by inexorable population growth. Inevitably, snowballing consumption increases the pressure on manufacturers, and also on the machines upon which they rely.
Binder USA offers M12 connectors with all external parts – threaded locking ring, housing, and pressing screw – constructed of stainless steel. The cable clamp is constructed of PTFE, the seal is made of Viton, and rounded surfaces facilitate cleaning.
Gears and gear racks used for transmitting torque and forces within gearboxes are typically made of hardened steel. For many other uses and applications, gears and racks made from plastic are the better choice. These generally require no lubrication and are lighter, quieter, less expensive, and more resistant to corrosion than metal gears. This is why JW Winco is expanding its range with polyamide gears and racks that can transmit high forces and torques.
