Following is a presentation of a gear design based upon a theoretically perfect gear technology, for which an overview is offered for consideration. What follows is a report on the design's testing and subsequent manufacture of a hypoid gear pair for a 1999 Ford Mustang.
A reader asks: I've determined that a stainless steel bearing is the best option for my application. I'm being asked to specify the grade of stainless steel in my product design. I'm not sure which grade to select and specify. Can you help?
"Well begun is half done," a quote that most reference materials attribute to Aristotle, certainly applies when selecting mechanical power transmission
products. A selection process that is well thought out at the start can ensure that the product selected will be properly sized and appropriate to the application at hand.
With the addition of Industrial Automation North America (IANA) as well as Motion, Drive & Automation North America(MDA NA), IMTS 2014 has greatly expanded its range of manufacturing technology services. These co-located shows complement the metalworking solutions found at IMTS by bringing in key suppliers from around the world.
At the recently held annual meeting of the Bearing Specialists Association, there was a lot of talk about online sales channels and how Internet retailers are changing the way industrial products are researched, sourced and purchased.
