Energy’s
endless energy efficiency
game of whack-a-mole, motors have historically always been one of the go-to moles. They’ve been in the spotlight since 1992. Over the past few decades, repeated efficiency laws have seen motor efficiency get whacked into tighter and tighter shape.
One of our goals at Power Transmission Engineering is to help you understand, identify and select the best technology for your mechanical power transmission or motion control applications. With every project, you have to decide which components to use, and which suppliers, based on functionality, quality and price. We aim to help you make those decisions informed by providing the latest information on current technology, especially when it comes to mechanical components.
Modeling and simulation is
a key driver of innovation.
Whether it’s general manufacturing,
consumer goods or life sciences, the
ability to realistically model and simulate the response of parts, sub-systems and complete assemblies to increase accuracy and repeatability is vital in today’s analytical world.
Moving around in open space
is a cautious endeavor. Without
the luxury of gravity, the slightest push can send you twirling in circles or, worse, tumbling off into the unknown.
Every motion must be thought out and
deliberate, all the more so because our bodies take that luxury into account.
