Looking at a Gear Cube XXL, you can't help but think about a Rubik's Cube. Both are 3x3 puzzle cubes with brightly colored pieces. Moreover, both are sold commercially as toys.
In planetary gear systems of high power density and high gear ratio, helical gears create undesirable tilting moments on the planet gears; therefore, spur gears are still preferred for planetary gears -- a special challenge with respect to noise. Specifically, the different behavior of planetary gears with sequential and symmetric gear mesh is explained in this paper.
Many industrial facilities with air-cooled heat exchangers (ACHE) and cooling towers often have older units installed. Depending on the age, repairs, and maintenance done over the years it may have had an impact on performance. Upon conducting site inspections of the equipment, it is sometimes found that ACHE or
cooling tower components have degraded. This can result in a system that is not very energy-efficient and delivers substandard cooling performance.
The Future of E-Mobility is a Mystery - One That Will Lead to the Same Innovation, Disruption and Ingenuity Found in the
Early Days of the Automotive Industry
