After a brief introduction to the importance of gear pumps in internal combustion engines, as well as in the most diverse hydraulic applications, a calculation method was applied that allows for sizing with considerably higher delivery rates. Upon identifying and analyzing a traditional pump, along with two construction solutions of asymmetric gear pumps, we then compared their related performances.
We are pleased to present our first annual Engineering Showcase, a celebration of some of the leading products and companies in mechanical power transmission. In the pages that follow, you’ll find examples of engineering excellence and technological know-how in the field of gears, drives, couplings, machine parts and other mechanical components.
This paper outlines the design considerations that go into construction of a drive system in order to explain the importance of specific data, why it is required, and where design freedom is necessary. Apart from loads and speeds, interface dimensions and site specific conditions are also needed. Deciding up front which gear rating practice to select can affect the torque capacity of the drive train by ~15%.
When software goes bad, what do we call it? System failure? Human failure? A virus? A number of words will work. How about this? Glitch. It has that onomatopoeic quality that fairly screams, Downtime! And with good reason -- software-generated miscalculations can have very expensive -- if not perilous -- repercussions.
