The air-oil, two-phase flow inside the multiple-point, oil-jet lubrication ball bearing was studied based on CFD (computational fluid dynamics) theory and technique, and compared with single-point, oil-jet lubrication. The results indicate that the air-oil distribution inside the bearing with multiple-point, oil-jet lubrication is more uniform than single-point injection.
The following news items offer the latest on lubrication and seal technology in the power transmission market. From bearing greases to high-performance seals, these products will help extend the service life and manufacturing capabilities for a wide range of industrial sectors.
Finding picture books for kids old enough to appreciate them can be a daunting task. There are, of course, the usual suspects--celebs, athletes, boy bands, girl bands, and so on, but not much of substance. That's where David Janosz Jr. enters the picture.
