Following is a presentation of a gear design based upon a theoretically perfect gear technology, for which an overview is offered for consideration. What follows is a report on the design's testing and subsequent manufacture of a hypoid gear pair for a 1999 Ford Mustang.
A reader asks: I've determined that a stainless steel bearing is the best option for my application. I'm being asked to specify the grade of stainless steel in my product design. I'm not sure which grade to select and specify. Can you help?
The scene is serene and picturesque.
Sunshine reflects off the light chop of the Ohio River, as a barge winds its way into view. While those driving
along Louisvilleās River Road may be inclined to reach for a camera to capture this idyllic scene, the mood
at Nugent Sand Company is anything but tranquil.
"Well begun is half done," a quote that most reference materials attribute to Aristotle, certainly applies when selecting mechanical power transmission
products. A selection process that is well thought out at the start can ensure that the product selected will be properly sized and appropriate to the application at hand.
