The AY110-40-01 Rotary Stage (pictured) from Optimal Engineering Systems, Inc. (OES) offers the users a high precision, low profile, compact motorized rotary stage. This precision stage with a diameter of 40 mm (1.575 in.) table is just 30 mm (1.181 in.) high and the footprint is only 133 mm by 57.5 mm (5.236 in. by 2.264 in.). The stage has an 8 mm (0.314 in.) aperture, a vernier scale, and a pattern of threaded mounting holes in the rotary table, and holes in the base for easy integration into new and existing applications.
The range of travel of this AY110-40 Rotary Stage Series is 360 degrees and it is capable of continuous rotation. The table is driven by a high precision 64:1 worm gear and has a resolution of 0.028126 degrees without a micro-stepping driver. The AY110-40-04 Stage has replaced the knob for manual adjustments with a Quadrature Optical Encoder for position verification.
The low cost, low profile AY110-40 Rotary Stage Series is ideal for: Microscopy, laser positioning and machining, inspection, assembly, testing, and other critical applications. This black anodized stage has a load capacity of 5 Kg (11 lbs) and there is an indicator scale for visual observation of the angle of rotation. The stage can be ordered as a complete plug-and-play system with RS-232, USB, joystick, trackball and keypad control, and fully compatible single or multi-axis controller.
