Spherical roller bearings (SRBs) have a higher load-carrying capacity and are more robust than other bearing products. This is why you’ll find them regularly in harsh environments such as mining, construction, and energy applications.
By definition, a spherical roller bearing is a rolling element bearing that permits rotation with low friction and permits angular misalignment. SRBs consist of spherical rolling elements, an outer ring, a cage as well as an inner ring with two raceways inclined at an angle to the bearing axis.
“The development of our bearing products continues on a daily basis,” said Martina Lenz, product manager, spherical roller bearings, at Schaeffler. “We’re looking beyond mere product improvements by paying close attention to the quality and reliability of the bearing itself.”
SRB technology has landed the component in unique applications including high pressure grinding rolls (HPGRs), pipelaying ships, Ferris wheels and even a Cold War–era marine espionage mission.
A Brief History of SRBs
SRBs were designed for systems in which high loads must be supported and shaft flexing and misalignment compensated. They deliver high performance characteristics while carrying extreme loads. SRBs have been improved and adapted to many industrial industries through the years with both FAG (now a brand of the Schaeffler Group) and SKF making key contributions to the technology throughout the product’s history.
“In the early days, these bearings were mainly used for transmissions and gearboxes focused on the industrial sector,” Lenz said. “In terms of moving into the rolling element aspect, this technology came directly from Schaeffler.”
In the renewable energy market, Schaeffler has been developing bearing solutions for on- and offshore wind turbines. Schaeffler technology can now be found in every second to third wind turbine, making Schaeffler a key supplier of wind-sector bearings worldwide. Optimized bearing systems in the gearbox significantly increase the load-carrying capacity and strength of wind turbines.
This is a state-of-the-art “standard” spherical roller bearing as it looks today; this type of bearing is typically used in heavy-duty applications with high radial loads and shaft misalignments. (Photos courtesy of Schaeffler).
“The decades of experience our engineers have gathered, combined with innovative ideas, improve our spherical roller bearings even further. As a matter of fact, our quest for perfection in development and production ensures optimum kinematics and low wear, which increases the service life even more,” Lenz said.
Replacement work is an additional area where SRBs shine, according to Lenz. Schaeffler split spherical roller bearings are the ideal solution for use in difficult-to-reach locations. Complex tasks can therefore be reduced to a minimum, significantly shortening machine and system downtimes.
Espionage and Intrigue in the Pacific
A phone call came in 1971 to Germany from US engineers on the West Coast with a specific request: They needed FAG Bearings to produce a unique triple-ring rolling bearing capable of meeting extremely strict load, stiffness, and accuracy requirements—10 million lb. radial load, 2 million lb. axial load and the ability to reduce startup friction by 90 percent.
Four of these 2,465 mm, 15.3 ton, bearings would be used in a 40 x 40 ft. marine application gimbal to prevent bending stresses from an intricate network of pipes. The lifting mechanism would be needed to pull large equipment out of deep ocean depths—basically an underwater mechanical claw attached to the ship’s surface.
“The triple ring design was intended to help facilitate the ‘gyroscopic effect’—as the middle rings turned slowly, the low-friction gimbal could compensate for the pitching and rolling of the ship, so that the mechanism’s frame would always be horizontal. This only works with triple-ring rolling bearings,” said retired Schaeffler Engineering Manager Heinrich Hofmann, who served as FAG-USA project engineer at the time.
While the components’ sheer size and technical data were impressive, it’s the application itself that adds excitement and intrigue to the story. The bearing in question was needed for a top-secret, CIA intelligence operation known as “Project Azorian.”
Unfortunately, lifting a 1,750-ton, 132-foot-long wrecked submarine from 3+ miles (16,500+ ft.) below the ocean surface—under total secrecy—isn’t the easiest of tasks.
An elaborate story was put together of a commercial deep-sea mining vessel—The Hughes Glomar Explorer—owned by eccentric billionaire Howard Hughes. This ruse suggested that the ship was simply conducting marine research at extreme ocean depths.
The vessel included a derrick like an oil-drilling rig, a pipe-transfer crane, two tall docking legs, a huge claw-like capture vehicle, a center docking well (called the “moon pool”) large enough to contain the hoisted portion of the sub, and doors to open and close the well’s floor.
The heavy-lift operation was extremely complex, according to the CIA museum. While maintaining its position in the ocean currents, the ship had to lower the capture vehicle by adding 60-foot sections of supporting steel pipe, one at a time.
When it reached the submarine section, the capture vehicle then had to be positioned to straddle the sunken submarine section, and its powerful jaws had to grab the hull. Then the ship had to raise the capture vehicle with the section in its clutches by reversing the lift process and removing supporting pipe sections one at a time until the submarine was securely stowed in the ship’s docking well.
This mission began on July 4, 1974, while the “commercial mining vessel” was being closely monitored by nearby Soviet ships. Although a portion of the submarine broke apart, the Glomar crew successfully hauled up part of the submarine providing deep insight into the Soviet Union’s strategic capabilities at the time.
The intricate, deep-cover operation was deemed one of the most expensive intelligence operations during the Cold War—costing an estimate $800 million then and roughly $4.4 billion by today’s standards.
High-Pressure Grinding Roll (HPGR)
A sealed SRB with a 1,950 mm outer diameter from Schaeffler was used in an HPGR for a mining application.
“The seals prevent the crushing materials from contaminating the bearing,” Lenz said. “The sealed bearing offers significantly longer operating life and can reduce the high cost of unplanned shutdowns.”
As bearing technology evolves, Schaeffler engineers work with their customers in the field to provide additional assistance and bearing improvements.
Until now, HPGR operation has required high quantities of grease to purge contamination from inside the bearings. While necessary, this practice wastes resources and significantly contributes to a mine’s preventive maintenance expenditures. By introducing a sealed bearing for this challenging application, Schaeffler’s innovation aims to not only provide state-of-the-art solutions, but increase mining productivity altogether.
“Our field engineers inspected these large bearings to determine if we could run the bearing longer or what the maintenance cycle may look like in the future. We’re regularly working with our customers in the field to provide feedback and additional maintenance suggestions,” Lenz added.
HPGRs are gaining more acceptance today in hard-rock processing primarily due to their energy efficiency benefits—sealed bearings can assist in making the crushing and grinding circuits much more sustainable in the future.
The Apache Maritime Vessel
A pipelaying ship, according to offshore-fleet.com, is a maritime vessel used in the construction of subsea infrastructure. It serves to connect oil production platforms with refineries on shore. To accomplish this goal, a typical pipelaying vessel carries a heavy lift crane, used to install pumps and valves, and equipment to lay pipe between subsea structures. Pipelaying ships make use of dynamic positioning systems or anchor spreads to maintain the correct position and speed while laying pipe. Advancements in technology allow pipes to be laid in water depths of more than 2,500 m.
The Apache 1 was an engineering project that ended up not being produced due to budget constraints, however, Schaeffler was involved in supplying triple-ring SRBs for the Apache II which was built in 1980.
“A different type of triple ring bearing was used for the Apache II. This design consisted of two outer ring halves and one inner ring. The two outer ring halves allowed for zero bearing clearance, which prevented damage to the rollers,” said Martin Grehn, former vice president development roller bearings at Schaeffler Technologies.
They had the pipelines on the land, welded together and the SRBs were ultimately used because of the distance between the components. These triple-ring bearings boasted a 1,750 mm outer diameter, as well as a weight of 6,000 kg.
The London Eye
This Ferris wheel—opened in 2001—is 135 m high, has a circumference of 424 m and a total weight of 2,100 tons. Its 32 capsules carry up to 25 passengers each. The wheel revolves at a speed of 0.26 meters per second, corresponding to a 30-minute ride for one full revolution—plenty of opportunity to enjoy London from above.
The wheel revolves smoothly thanks to the large FAG SRBs, each of them with an outside diameter of more than two meters and weighing several tons. The two spherical roller bearings were mounted in a locating/floating bearing arrangement in the hub on the axle of the Ferris wheel.
The two large GE440-DW spherical plain bearings from Schaeffler were essential for slewing the wheel from its horizontal mounting position across the Thames into its vertical operating position (slewing angle of more than 90°) with a resulting contact pressure of more than 450 N/mm2.
Since then, the spherical plain bearings have had the task of compensating for wind-induced micromovements that would otherwise have an adverse effect on the comparatively stiff steel
construction, according to Jens Fella, vice president research and development, spherical roller bearings and mechanical systems at Schaeffler Technologies.
Thanks to ELGOGLIDE, Schaeffler’s proprietary PTFE sliding layer, the large spherical plain bearings are maintenance-free and can accommodate extremely high loads with low moment levels. This guarantees long life even with contact pressures of 362 N/mm² that are very high for radial spherical plain bearings. If it hadn’t been for the large spherical plain bearings from Schaeffler, a totally different static design would have been required so that the wheel would probably look much less elegant today.
“Although many of our SRBs boast a standard design, we see a growing trend in custom bearings for unique applications like this,” Fella said. “At the time the London Eye opened, it was the largest Ferris wheel in the world. They originally wanted the bearings to run for roughly a year, possibly a year and a half, but they’ve been running without issue for more than 22 years!” Fella added.
A Constant Evolution
As far as the evolution of SRBs in the future, Lenz believes sustainability and energy efficiency will remain the most important factors in the coming years.
“Further lowering friction is going to be the next step. Downsizing options will also play an important role in the future as this industrial trend continues,” Lenz said. “All of the changes we might make will always be designed with sustainability in mind.”
Friction, CO² reduction, the green bearing of the future, these are all important customer requests in today’s market.
“If we can provide green components, this will give the customer an opportunity to provide products that are more energy efficient, sustainable and require less maintenance,” Lenz added.
