Home » Eight Reasons to Use Air Bearings Over Mechanical Bearings
December 1, 2016
Mechanical guiding systems, such as crossedroller bearings, work well for most motion control applications; however, when precision, angular repeatability, and geometric performance
(runout, straightness) are critical or
where submicron bearing rumble is problematic, air bearings are recommended. An air-bearing stage is a rotary or linear positioner that floats on a cushion of air, using one of several preload mechanisms, nearly
eliminating mechanical contact and thus wear, friction, and hysteresis effects. Here are eight reasons why an air-bearing stage might be the right choice for your application:
