Visitors to the company’s booth can view a demonstration of the Regal Rexnord ModSort plug and play, divert and transfer module. ModSort is an electric-powered sortation solution capable of handling a range of products from small polybags to boxes up to 30 kg at rates up to 3,000 pph. The unit is powered by an energy-efficient and safe 120V AC power supply, and operates at only 72 dB, about the same amount of sound generated by a household washing machine.
ModSort uses System Plast belts, which utilize rotating spheres to provide a high degree of motion control and the ability to convey packages in any direction. The system installs in under a week, and additional sort zones can be added or removed to accommodate future changes in capacity requirements. As a last mile sorter, Modsort eliminates the need for manual sortation while contributing to a quieter, safe and energy-efficient work environment.
