Magnetic Sensor Systems (MSS) has released their S-20-100X model of Pull Type Tubular Solenoids. Their S-20-100X series of solenoids features 18 different solenoids to select from based on the voltage, duty cycle, force and stroke requirement of the user. MSS Solenoids coils typically utilize Class “F” 23 to 40 AWG (American Wire Gauge) windings with Class “A” insulation for better protection of the solenoid during longer duty cycles.
The S-20-100X solenoids feature a 1.000 in. diameter x 2.000 in. long housing and a 3/4 -16 UNF-2A thread for mounting. The noncaptive plunger or actuator has a diameter of 0.437 in. with a clevis end for load attachment. A low friction brass guide and PTFE coating on the plunger assures exceptionally long life.
These clean, high efficiency, low cost, precise tubular solenoids can be operated at 1/10, 1/4, 1/2, and continuous duty cycles (voltage dependent) and are the ideal choice for: Vending machines, medical dispensing, mixing, valve control, farm machinery, disconnects, transmission shifting, fire suppression systems, cabinet locks, door controls, and sorting equipment.
