SDP/SI is a total solutions provider able to take your project from concept to completion. Offering a wide range of standard components, custom solutions, manufacturing, engineering, assembly, and world-class quality, we partner with our customers ensuring their success. Explore the many ways we can help.
Consisting of a rotor and stator, the Frameless motors are delivered without bearings and motor shaft and are connected during assembly. The compact size, high torques, and large space for cable routing allow for integration into a wide range of applications. Discover the possibilities.
Choosing the right motors, controllers, and drives can sometimes be challenging due to the many variables and options. Frameless BLDC motors fit easily into small compact machines that require high precision, high torque, and high efficiency, such as robotic applications where low weight and inertia is critical. Learn more.
When faced with a design challenge engineers reach out to SDP/SI for their expertise in small power transmission solutions and its engineer-to-engineer support. A frequently asked question is which is better, a timing belt and pulley drive system or a gear drive? Discover the advantages and disadvantages of both.
When designing a drive system for a power transmission application, a timing belt and pulley drive system is one of the most common, but is it the best solution for you? To determine the best system for your application needs, explore your options.
