This white paper will explore the need to bring mechanical engineering expertise and creativity to automated systems design early in the process. It will show how engaging with an experienced mechanical system integrator such as DieQua Corporation leads to more successful outcomes.
In the simplest definition, a line shaft is the rotating shaft part of a system of mechanical couplings between the power source and the machines that do work. Line shafts, also known as connecting shafts, jack shafts, or link shafts, are used to span long distances between rotating components. Conventional solutions typically involved two standard flexible couplings and solid shafting, requiring intermediate pillow block bearings for support. Newer style precision line shafts can be operated at lengths of up to 6m without any intermediate support required.
Design engineers seek the most efficient and reliable solutions to their applications. While often times standard products are ideal, there are instances when an application challenge requires something other than a standard solution.
Cycloidal speed reducer technology reduces the speed of a motor’s input shaft by a predetermined ratio, matched to the application and the type of equipment used. These high-precision devices deliver relatively high reduction ratios, even for sizes as small as 50 mm in diameter. Speed reducers are essential for precise motion control in sophisticated systems such as robotics, military/defense equipment, and satellite antennas.
Gearboxes are essential components for machines in practically every industry. They must comply with the environmental, safety, and production/efficiency regulations and standards for these industries. Environmental performance can be especially challenging because the operating conditions are harsh or extreme. Fortunately, standard gearboxes are extremely sturdy components that can be modified to fulfill almost any application or requirement. In this white paper, we discuss the many challenges food and beverage industries present for gearboxes, and how to mitigate them.
There is a widespread push to replace hydraulic systems with electo-mechanical screw jack systems and for a number of good reasons. The trend has already been under way in Europe for some years and now it is moving to North America. Engineers are being tasked to “design out” hydraulic systems and “design in” screw jack systems for their pushing, pulling, lifting and holding application needs.
