In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
Cortec Corporation is pleased to announce the development of its latest VCI film and bag technology: CorShield VpCI-220E. The new formula not only offers improved corrosion protection but also includes 30 percent post-consumer recycled content.
The range and flexibility of lubrication and sealing technologies continues to expand as companies look to scale down production times while increasing productivity. The industry is focused on environmental impact, automation and compact systems. Here’s just a few of the latest technologies in the industrial market:
Stainless steel ASK Couplings from Miki Pulley feature a unique “sliced” body structure making them an effective low-cost corrosion resistant solution that can accommodate many types of misalignments. The stainless-steel design makes them ideal for use in food and chemical applications.
NORD’s nsd tupH sealed surface treatment is available as an option with a variety of their modular products and provides an easy to clean surface suited for harsh processing and manufacturing environments.
