Wear is a very important topic for dry running plastic gears. Over the past few years,
the authors have worked closely with a number of manufacturers of plastic gears
to investigate the problems of gear wear in detail. Together they have developed a calculation method that can be used to predict where and when local wear will occur on a tooth flank. Their findings have also just been published in the final version of VDI 2736.
Wind turbine gearboxes are subjected to a wide variety of operating conditions, some of which may push the
bearings beyond their limits. Damage may be done to the bearings, resulting in a specific premature failure mode
known as white etching cracks (WEC), sometimes called brittle, short-life, early, abnormal or white structured flaking
(WSF). Measures to make the bearings more robust in these operating conditions are discussed in this article.
Even when the critical components of industrial power transmission gear drive systems are properly designed, specified
and manufactured consistent with application requirements, performance
problems can develop over time and failure may follow.
More than a decade of intensive research and development has resulted in two new technologies that, when used in combination, expand the performance of rolling element bearings well beyond previous limits.
Based on simulation methods and calculation tools developed by the Schaeffler Group and presented in the first part of this paper, three approaches regarding increased efficiency based on rolling bearings are presented.
The Magnetic Gearing and Turbine Corp. (MGT), founded by Australian inventor Andrew French in 2000, manufactures injection molded gears and couplings based entirely on magnetic technology. The repulsive magnetic forces are used to transmit power without losing any energy, and drive shafts rotate completely independently of each other.
