This paper provides an overview of the more common position sensor options and references actual case studies to
illustrate the diverse solutions available and the reasons behind some of the decisions. Three cases are used to illustrate the needs of different applications leading to the choice of a particular type of position sensor. The cases reviewed include a gantry crane, wind turbine and aerial cable car.
When a bearing is damaged, it is often removed from service and replaced before it reaches its full, useful and economical life. Advancements in bearing design, materials, bearing maintenance and repair methods have greatly improved the potential for and popularity of bearing repair as an effective way to extend the life of the bearing.
