It’s called the d2, a small, lightweight, nanoliter microplate dispenser—say that five times fast— used in lab automation to handle a variety of liquids. Created by UK Robotics, the liquid handler was launched in 2022 to shakeup the possibilities of moving liquids around the lab on a budget.
Orbex Group, a U.S.-based supplier of slip rings and electric motors, has introduced two new custom products to its offering of precision motion solutions. These custom flat brushless DC (BLDC) motors provide smooth motion, high precision and excellent power density, as well as an integral gear reducer in a compact package.
Nidec Leroy-Somer has signed an agreement with Airbus to develop an electric motor for its hydrogen-powered fuel cell engine prototype, as part of Airbus’ ambition to bring the first zero-emission commercial aircraft to market by 2035. The long-standing expertise and extensive know-how of the French electric motor manufacturer, who already provides proven advanced technologies to many demanding industries, such as Navy, Nuclear, Railway, Automotive and Robotics is now collaborating on Aviation decarbonization.
February 2, 2023
The Electrical Apparatus Service Association (EASA) announces its Spring 2023 training seminar schedule. Offered in various locations around the United States, EASA's industry-specific training pools more than 100 years of rotating equipment knowledge from EASA's technical support staff. Participants have an opportunity to interact face-to-face with the presenters, as well as each other.
With over 200 years of combined experience, Interact Analysis is the market intelligence authority for global supply chain automation. Our research covers the entire automation value chain – from the technology used to automate factory production, through inventory storage and distribution channels, to the transportation of the finished goods. The world’s leading companies trust us to surface robust insights and opportunities for technology-driven growth.
This Oriental Motor article provides more information on these types of noises and what can be done to minimize the noise. It's important to remember to isolate the motor from any other noise-making source, such as metal plates or loose bolts. It's also very useful to have an extra motor in good working condition for noise comparison, so you have a reference point.
The new production plant is officially in operation after its formal unveiling at Lafert’s 60th anniversary celebrations in San Donà di Piave, Italy, close to the historic headquarters.
