The R-09-150 CWN Series of Clockwise, Reverse Shaft Extension Rotary Solenoids from Magnetic Sensor Systems (MSS), available in OEM quantities, features 18 different winding configurations allowing the user to match torque and duty cycle requirements to an application. These compact 38.1 mm (1.50 in.) diameter solenoids are just 22.1 mm (0.87 in.) long and have two M4X0.7 threaded studs (8-32 studs optional) 7.4 mm (0.29 in.) long on a 22.2 mm (0.875 in.) bolt circle. The reverse shaft has 40 degrees of clockwise rotation, extending 13.0 mm (0.51 in.). Shaft end is serrated for better grip of the attached load.
The miniature GVCM-019-032-02 Linear Voice Coil Servo Motor has been released by Moticont. It is only three-quarters of an inch (19.0 mm) in diameter and features a 0.875 in. (22.2 mm) stroke. Also called an electric cylinder, this miniature linear servomotor, features a continuous high-force-to-size ratio of 7.4 ounces (2.1 N) and 23.3 ounces (6.5 N) of peak force at a 10 percent duty cycle.
The HVCM-051-032-013-01 Linear Voice Coil Motor released by Moticont, features a high force-to-size ratio and a 19.1 mm (0.75 in.) stroke. A low inertia, high acceleration/deceleration, high speed, clean and quiet, non-commutated, hollow core brushless servomotor, the HVCM-051-032-013-01 Linear Voice Coil Motor is ideal for applications such as: Testing, optical focusing, positioning, laser beam steering, laser drilling, cutting and machining, medical diagnostic equipment, scanning, wafer handling, dynamic vibration absorption, sorting, and assembly applications.
Helukabel recently announced two acquisitions to further grow its core competency in the field of industrial automation. The two latest companies to join the Helukabel Group are ekd gelenkrohr GmbH, a drag chain manufacturer, and Sangel Systemtechnik, an industrial cable assembly manufacturer.
A high force-to-size ratio is just one of the many features of Moticont’s GVCM-051-089-02 Linear Voice Coil Actuator with Built-in Bearing. The actuator applies up to 66.4 N (14.9 lbs.) of continuous force and 210 N (47.2 lbs.) of peak force.
