SKF has expanded its portfolio of Condition Monitoring solutions with the SKF Enlight Collect IMx-1-EX sensor solution. Wireless monitoring of assets helps predict machine failure before it can escalate into a serious problem, such as an unscheduled shutdown. This can deliver multiple benefits, including reduced costs and a more sustainable operation of equipment.
ONYX Insight has unveiled a new upgrade to its fleetMONITOR technology which will enable wind operators to monitor the health of their turbines using data from Bently Nevada System.
NTN, the parent company of BCA Bearings and Bower Bearings, is proud to announce the receipt of a 2023 Automotive Communications Award from Women in Auto Care. NTN received the award in the “Business-to-Business – Promotional Goods, Gear, Marketing Collateral” category for its BCA and Bower “Summer Cruisin”
Promotions.
Routine refurbishment of important rotating machinery is vital for continued, reliable operation but if the original equipment manufacturer (OEM) fails to deliver an optimum service, what other options are available? For one oil company in Nigeria, issues with a gas compressor following an overhaul led to the maintenance team looking for an alternative solution. Sulzer was then selected to support the oil company, not only for its extensive experience in this equipment, but also its local service center that offered a tailored approach.
Burckhardt Compression recently partnered with one of Europe's leading steelmaking mills undergoing a significant transformation. The mill aimed to convert one of its plants into a sustainable facility in compliance with stringent environmental guidelines. The project's critical aspect involved reviving four non-Burckhardt compressors that had been inactive for a decade. Acknowledging the crucial role of these compressors in steel production, the mill sought the expertise of Burckhardt Compression.
From manufacturing to maritime, the quest for sustainable solutions has given rise to the development of environmentally friendly lubricants. Among these, Environmentally Considerate Lubricants (ECL) and Environmentally Acceptable Lubricants (EALs) have gained prominence for their positive impact on both equipment performance and the planet. Let’s delve into the differences and advantages of these lubricant classifications.
The Dune Express is a 42-mile long, fully electric conveyor system that is expected to transform the Permian Basin and substantially improve the unacceptable safety risk existing on the Permian roadways. Originating from the Kermit, Texas facility and spanning into New Mexico, the Dune Express is intended to eliminate millions of truck miles driven across the Permian resulting in avoided traffic, accidents, injuries, and fatalities within the communities.
A worldwide manufacturer of many types of plastic has manufacturing facilities around the world, including one in the southeast that makes PVC stretch film. Imagine the film used to wrap meat at your local neighborhood grocery store, or that you might use to keep leftovers fresh for later in the week. Although the plant is designed for precision and automation, sometimes mechanical components derail those plans and require operator interaction to correct the components shortcomings. The clutch-brake on a turret winding system was not precise, which not only required operator interaction but also caused downtime. Replacing the dry clutch brakes with Force Control Oil Shear clutch brakes eliminated downtime, increased accuracy and repeatability, and slashed operator involvement – all while increasing throughout.
Mechanical motion components, though relatively small, contribute immensely to the safety of multiple systems like automobiles, manufacturing systems, elevators, water treatment facilities, etc. Motion components experience wear and tear over time caused by:
Friction as motion surfaces come into contact with adjacent components.
Corrosion due to exposure to chemicals, humidity, and corrosive gasses
Fatigue emanating from repetitive stress and strain.
The Power Transmission Distributors Association (PTDA) welcomes three new distributors to its membership including Gordon Russell, MROSupply.com and Grainger.
