David Brown Santasalo (DBS) was delighted to recently welcome valued customer, Breedon Cement’s new intake of apprentices, reliability engineers and their mentors to their Park Works, Huddersfield, UK facility for a day of training delivered by DBS’ Development Director, Mike Field.
The Ogura MCNB-HS Series power-off spring applied brakes have oversized bores to allow wires to pass through the shaft’s hollow bore. They accommodate encoders, cables, hoses, shafts, and tools. The ratio of the brake’s field core diameter to outer diameter is leading the industry.
Corrosion under insulation (CUI) is a longtime plague of petrochemical, refinery, and marine environments. The problem is so bad that an estimated 40-60 percent of piping maintenance costs in the oil and gas industry stem from CUI-related expenses. Even worse, undetected CUI on pipes carrying hazardous liquids may lead to leaks and potential explosions. To tackle this dangerous and costly problem, Cortec Corporation has developed CorroLogic CUI Inhibitor Injection, a new Vapor phase Corrosion Inhibitor technology that simplifies protection for insulated pipes reaching a high range of temperatures.
SKF continues to expand its RecondOil offer through a partnership agreement with Castrol, one of the world’s leading lubricant brands. The partnership will enable Castrol industrial customers to use integrated RecondOil Double Separation Technology (DST) systems.
Force Control dynamometers featuring Positorq oil shear load brakes absorb extreme torque at very low speed, down to zero rpm. This allows them to accurately capture data at these critical junctures, when dynos equipped with traditional load brakes cannot.
Emerson Bearing recently delivered this great back to basics blog on rod ends. Emerson Bearing and Action Bearing serve the bearing needs of international and domestic customers. The team at Emerson Bearing caters to global niche markets, while the team at Action Bearing, specializes in solutions for the OEM and MRO markets in New England.
David Brown Santasalo Australia recently completed a full strip and rebuild of a Zollern ZHP 4.33 Rope Winch Drum for valued mining industry partner, Zollern. The 7,550 kg Winch Drum powers a coal loader, with an output torque of 400 kNm (Stat Max) and an input torque of 893 Nm.
