Drop-in system offers tightest inner radius in the market for reduced footprint
February 8, 2023
Regal Rexnord Corporation introduces its new Rexnord Curve System with 1540 Series MatTop Chain for conveyor lines requiring a zero tangent 180 and/ or 90-degree curve. The system offers the tightest inner radius (420 mm) and smallest transfer (15 mm) in the industry, for greatly improved space utilization and package handling.
Vesconite contributes to a communication satellite launch
February 7, 2023
Vesconite Bearings, through its supply of marine rudder bearings to the MN Colibri charter vessel in June, is proud to be associated with an exciting communication satellite launch that took place in September 2022. The MN Colibri has historically transported launcher components, including communications satellites, for various heavy-lift space launch vehicles, and outfitted with the Vesconite rudder bearings allowed it to transport the Eutelsat Konnect VHTS satellite, which is regarded as an important addition to global telecommunications infrastructure.
The Timken Company has acquired the assets of American Roller Bearing Company (ARB), a North Carolina-based manufacturer of industrial bearings. ARB's offerings join Timken's industry-leading portfolio of engineered bearing solutions. ARB, which boasts a large U.S. installed base and strong aftermarket business, generated sales of more than $30 million in 2022.
Commercial garage doors range in many sizes and configurations requiring a “just right” model and size brake for reliable automatic operation. Depending on the design and size of the overhead door and placement of the brake, a variety of brake models and sizes offer solutions from the Miki Pulley brake lineup.
Racaw Ltd., a designer and manufacturer of precision positioning components and systems, required reliable shaft couplings for use on its lines of linear and rotary positioning stages. The stages allow precise linear and rotary positioning of objects via a stepping or servo motor with rotary encoder control. Huco Oldham couplings were selected because they met Racaw’s torque capacity range, zero backlash, auditable noise and vibration levels, lengthy predicted service life and availability requirements.
MagnaShear motor brakes, which provide a secure, no-maintenance, no-adjustment, holding brake solution for mining conveyor applications will be featured at MinEXCHANGE Booth #2720.
Timken Utilizes LK Metrology for Bearing Inspection and Analysis
January 9, 2023
The Dudley, UK factory of The Timken Company supplies the engineered bearings it manufactures into a multitude of industries including mining, food and beverage, pulp and paper, cement, marine, and wastewater. Recently there has been a significant increase in demand for larger bearings up to 1,200 mm in diameter for use in the construction of wind turbines, which promises exponential growth in the coming years as countries across the globe work towards meeting their green energy targets.
As of January 2023, Arkos Field Services, acquired by Burckhardt Compression in 2019, is integrated with Burckhardt Compression (US) Inc. Customers benefit from combined knowledge, expertise and unrivalled solutions for reciprocating compressors and other equipment from one provider. The integration of the two brands streamlines business processes to provide easy access and a solutions-driven customer experience.
