The Magnetic Gearing and Turbine Corp. (MGT), founded by Australian inventor Andrew French in 2000, manufactures injection molded gears and couplings based entirely on magnetic technology. The repulsive magnetic forces are used to transmit power without losing any energy, and drive shafts rotate completely independently of each other.
Robotics and other advanced automation technology systems are viewed as a looming threat to some in the plant
maintenance field. Although there is
a constant battle for some workers to
remain useful while machines are continuously fulfilling more roles on the plant floor, there are those who in turn have found a better use of their newly freed time.
Can direct drive technology improve your bottom line? Manufacturers relying upon drive systems in their production process have long sought ways to improve gearbox efficiency. While a gearbox-driven system has been the mainstay for manufacturers, it has also been, among other things, the source of frequent breakdowns, expensive line stoppages and increasingly costly maintenance.
Part I of this article appeared in the
October 2008 issue. It provided an overview and general classifi cations of power transmission couplings, along with selection and performance criteria for rigid couplings and misalignment-compensating couplings. Part II continues the discussion with selection and performance criteria for torsionally flexible and combination-purpose couplings.
