It was recently announced that the planet Mars has at least one thing in common with planet Earth: all good things come to an end. In this case, the good thing is the recently announced and documented (Feb. 12) demise of the Mars rover Opportunity.
Free vibration and dynamic operation testing of hybrid gears at NASA Glenn Spur Gear Fatigue Test Facility; hybrid gears are compared to their steel counterparts.
He was out.
Nine years ago, Ross Rivard left the
coupling industry for the shimmering
new world of luxury automotive components at Lacks Enterprises, where he was immediately enveloped by platinum trim systems and chrome composite wheels. It was glitz and glam and as sparkly clean as the fresh-fromthe-dealership cars his products were embellished onto.
